Hi I have an ideal logic combi 35 with a Honeywell cm907 digistat installed in my new build. The problem is the boiler struggles to get up to 23degrees then won't go any higher. The property is a 2 bedroom mid terraced house so I'm sure the 35kw output is plenty. I have 3 downstairs rads and 3 upstairs all have TRV's apart from the main radiator in the livingroom where the digistat is. I have bled and balanced the system and the boiler temp is turned up to max. Any suggestions on how I can fix this?
