- Joined
- 22 Oct 2020
- Messages
- 3
- Reaction score
- 1
- Country
I have a 2 year old Ideal Logic Combi C30 boiler and have recently started to have some trouble with it. I live in an early 20th century 2 bedroom terraced house.
When I want the radiators on, they do not reach the target temperature. For example, I have it set to 'E' (eco mode), which should bring the radiator temperature to 68 degrees, but the boiler will only raise the temperature to 48 degrees and no higher.
I have had two engineers visit from Ideal. The first engineer was not too sure what the issue was and the second engineer has replaced the circuit board as he felt that this might be the issue. Both engineers said the boiler was in good condition and there was no obvious problem with it.
The only solution so far has been to turn it on and off at the fuse switch. After a hard restart, this will then bring the radiator temperature to the correct target temperature. However, this is only a temporary fix becuase if you want to have the heating on the following day then it will not go above 48 degrees again.
It is annoying because I have not had an issue with the boiler for the last 2 years and it has been great, it has suddenly started playing up...
Does anyone have any advice or suggestions?
Thanks in advance
Thanks in advance
