Not sure if this has been covered before but my boiler is struggling to fire up in the mornings.
It's an Ideal c24 mini, recently replaced the exp tank and pressure relief vavle, but noticed that on starting up the plunger comes out of the diverter valve to activate the switch, then backs off a bit about, 1mm, but this de activates the switch and therefore won't fire up. I replaced the diaphragm but still no joy.
So I stuck a 1mm strip of plastic to the switch arm, worked fine for a few weeks, then I had to stick ANOTHER strip of plastic to the switch as the plunger was backing off a bit more.
This did the trick for another few weeks, and now it's playing up again, the plunger is backing off even more and I don't really want to stick yet another piece of plastic on the switch.
I have to keep switching it off and on again at the plug, about 6 or 7 times before it fires, I can tell when it will fire as I can hear the fan cutting in, once fired up it switches off and on again all day with no problem, it's only in the mornings that it plays up. Pressure is always on about 2 bar.
The main question is why does the plunger come out to the switch then back off almost immediately?
Any ideas would be greatly appreciated. Gordon
