Ideas for protecting drain pipe from parking mishaps?
5 Apr 2011
Surrey
We have gutter drainage pipe running down the front of our house, draining onto the driveway. From time to time it gets hit by cars parking on the drive - the drive is quite small, and if any wheels are left on the pavement the driver may be ticketed. When it gets hit it usually dislodges the connection with the gutter (at the top of the house), so I want to install something to protect the downpipe from parking cars.
The pipe protrudes roughly 8.5cm from the wall. I also need to find something to raise it slightly.
Does anyone have any ideas for something which can be used to shield the downpipe from cars which may bump into it?
No - we discussed this with the guy who installed it, and there was no good alternative location for it
Maybe add a photo of where it attaches to the gutter, for a second opinion on that, but...
Would I be correct in assuming that it just discharges on the ground, rather than into a drain?
Looks like it, I can see an open shoe at the bottom.
I think the fitter is being lazy I reckon it could easily be turned around the corner but I would fix some sort of rubber in its place seeing as you use your bumper as a parking aid :LOL:
You could easily divert that pipe up high to come around the corner and down, or even at waist height. You’d gain 4”
You could make /find a metal bracket to protect the pipe physically but potentially damage the car/ lose space.
You could stick a 1M bendy rod in the ground in front of the pipe asa visual reminder
Same rod but have a small hoop that it goes through (both metallic) so that if hit it completes a circuit.
Loud buzzer/light at window height connected to buzzer
Screw an L bracket to the wall, length of string and tennis ball hanging.
Old bulb horn !
Here's a wider angle shot
Would there be any value, in moving that fall pipe around the corner, on the left, so it discharges around that corner, but digging out a bed of concrete, to form a channel to get it around the corner, to where it presently discharges?
Could you clarify, where it is presently discharging? It looks as if it is just discharging onto the ground, or the gully is completely blocked up.
I suppose you will be aware, that the second 45 down from the gutter hopper, is disconnected, and so not doing very much?
