If fitting a drinking water fountain is a double check valve required?
9 Aug 2009
Blackpool
If installing a drinking fountain is a double check valve require on the cold feed to it?
Depends on the type of fountain. Is it WRAS approved? What do the installation instructions say?
I am not a plumber but would guess not as there is automatically an air break
If it is a downwards facing outlet then I would say probably not as it is similar to any tap with an air gap.
But if it is an upward facing jet then almost certainly as spit and any nasty stuff can fall into it by gravity.
Thanks not seen it yet off to look tomorrow. Agile your description of when one may and may not need one makes sense.
It was not a description but only my assessment based on general Water Regulation principles.
It did not come into my Water Regulations course!
Thanks its and upward facing jet, so will fit a double check valve. Also does anyone know what kind of height to set at. Would the normal basin height 820mm be about right?
Up, or downwards, would be irrelevant if the design of fountain has a water catchment area which, if the drain outlet should become blocked, would cause a pool of water to collect above the level of the water outlet. This would require double check valve.
It wouldn't no. Its just that as agile say spit etc could fall on the tap with it having an upward facing spout.
Southern water insist on a DCV due to risk of contaminants.
So Tony is sort of right :confused:. But he probably Googled
Thanks all I noticed with it is if you pressed the button down fully, it over sprayed over the fountains catchment area.
