Just discovered we've no hot water. Boiler is Potterton Promax 24 HE Plus Checked the obvious things like boiler/water pressure etc. They're fine and no error codes on boiler. So, tried a reset and the boiler fan starts up but no ignition. So, moved to next step of investigation (after some Googling and dismissing condensate trap etc) and took front cover off and found the following
As you can see, the ignitor looks burnt. There's white powdery stuff in the boiler case (from the ignitor?) and I'm not sure about the condition of the top of the door/boiler shell)
[img]http://thumbsnap.com/s/4Y49SrdQ.jpg[/img]|http://thumbsnap.com/4Y49SrdQ
[img]http://thumbsnap.com/s/B1W0NM1l.jpg[/img]|http://thumbsnap.com/B1W0NM1l
[img]http://thumbsnap.com/s/ROeVWslp.jpg[/img]|http://thumbsnap.com/ROeVWslp
Can someone suggest root cause possibly? I'll obviously get a GasSafe person to do whatever's required but would welcome some info. Probably not related but recently had new bathroom fitted so water off at different times and boiler drained down etc - Megaflow system too.
Many thanks in advance
