Ikea integral hinges
4 Feb 2009
Yorkshire
Hi
I am building some cupboards on the bedroom, using ikea integral hinges.
Just wondered if someone could tell me the distance to mount the hinges from the door edge. Using 18 mm MDF.
Andy
Just done that, hinges normally set 17mm from edge but I found Ikea hinges need 15mm. They are clip on so helps when installing, centre the mounting plate when marking out and then you will have approx 2mm adjustment up an down and about 3mm in and out at the hinge.
Check the design of the hinge, I had two different styles in the pack so best to match them in case they vary slightly.
They are designed for 18mm material so for I.E a pair of 500mm doors need a carcase 1000mm wide to outside edge.
[The 500mm doors are actually 495mm]
