    Dismiss Notice
I'm detailing a secondary ceiling to separate two flats in an old Victorian town house.
Discussion in 'Building' started by MrBird, 14 Nov 2018.
  1. MrBird
    MrBird
    14 Nov 2018
    3
    Thanks Received:
    Country:
    The proposed method is to use clear span secondary joists to support two layers of 12.5mm plasterboard with batts between the joists. I am trying to optimise joist spacing and depth. Joists to be support on hangers off new wall-plate under the existing sandtex-overpainted high-relief coving (by deceased vandal). Any suggestions, please - I assume deflection mitigates against C24 timber.
  2. Sponsored Links
  3. bernardgreen
    bernardgreen
    3 Nov 2006
    23,747
    Thanks Received:
    2,287
    Bedfordshire
    Country:
    Not sure that that would provide adequate fire resistance.
    Local Building Control would need to accept the design as being suitable for compartmentising the two flats to prevent spread of fire from one flat to the other.
  4. tony1851
    tony1851
    23 Feb 2012
    9,799
    Thanks Received:
    1,463
    Manchester
    Country:
    What's the span?
  5. MrBird
    MrBird
    14 Nov 2018
    3
    Thanks Received:
    Country:
    Thank you both.
    I've discussed with local Building Control who are content with the proposal, provided the wall joint is fire-sealed. Specifically, they have accepted existing lath & plaster ceiling without additional plasterboard, which would be difficult given the extent of debased mouldings.
    Spans are 5.1m into the alcoves or 4.75 to the chimney breast. I could put a jack-beam across each of the alcoves to reduce the span.
    I want to avoid using suspension from floor above to reduce sag of beams -especially long term.
    Has anyone used cold-rolled Z-sections for the work?
  6. Sponsored Links
  7. tony1851
    tony1851
    23 Feb 2012
    9,799
    Thanks Received:
    1,463
    Manchester
    Country:
    You would be looking at something like 125 x 50 C24 @ 300 centres to keep deflection within resonable limits.
  8. Have Building Control said it will be subject to sound testing when completed ?
  9. big-all
    big-all
    12 Jul 2004
    18,432
    Thanks Received:
    1,422
    Surrey
    Country:
    exactly my thoughts
    are they aware its not a single dwelling ??
  10. bobasd
    bobasd
    2 Dec 2017
    2,373
    Thanks Received:
    446
    Country:
    this seems to be a ground floor room with first floor joists above - so where's the issue in fixing boards to the existing ceiling and joists?
    Plasterboard can easily and neatly be pinned up leaving a definite shadow line about 5mm to 10mm short of the moulded coving.
    More important is that BCO allowed such a fire risk dropped ceiling in a flat below a flat?
    Do your multiple occupancy insurers know about this design?
    If a Fire Service inspection is necessary they can impose powerful conditions or fail it.
    Maybe nobody cares but i know the fire service loathe dropped ceilings of any kind according to their inspector.
  11. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
