I have a old style Hot water and CH system. I have the cylinder in the airing cupboard with the pump and divertor valve. The system is about 15 years old but never gave any trouble so far.
I've recently noticed that the CH no longer comes on even if I turn the thermostat to max (30). I had this problem last year but I replaced the thermostat and that cured it. So this time I did the same but the problem persists.
Hot water is working just fine. the pump comes on and the diverter valve is in W position & boiler switches on. With only CH on the pump does not come on and the diverter is still in W position. Makes no difference if both CH and HW are on at same time. I only get the boiler coming on to make hot water but not when I want heat.
I'm not sure if the problem is the controller (Drayton LP241) or the box in the airing cupboard which the pump and diverter are connected to. The controller is only £35 so I might just take a punt and replace.
How would I go about diagnosing the fault to determine which bit has failed. I don't have a multi-meter but I do have a probe that can test for power.
Thanks for any help.
