Hi all,
My house purchase finally went through and I've removed most of what
was left in there and starting from scratch. It's not habitable at the
moment (hence why I've not been on here trying to tackle all the leeccy
questions) and being an electrician doesn't really come in too useful when
I'm attempting building work or plumbing etc, but I'm glad to say the only
trade I'm going to end up paying for is a plasterer and a plumber to do the
gas bits. The plumbing has taken a while, I had to move the water main
by digging down though the concrete past the damp proof membrane,
joining onto it and re-routing it below the concrete to where I wanted it. All
of the rad's are plumbed in, I've joined onto the existing hot and cold
water pipes in the house and the boiler is hung though it was a little
daunting positioning it perfectly for the flue to exit vertically through the
tiled roof. I've learned loads about plumbing just by buying all the stuff
myself and I've found it easier than I thought. Just waiting for the corgi
man to visit to run the gas pipe, fit the flue and commission all the
unvented bits and pieces. I've got to (at the request of the afore-
mentioned corgi man) run a 28mm discharge pipe for the unvented
cylinder; this seems a bit big to me (15mm outlet and 22mm leaving the
tundish supplied with the unvented kit) but then I'm not a plumber..... I've
removed the huge electric warm-air heater from a cupboard which was in
the middle of the house and knocked the wall down which formed the
cupboard for it, making the kitchen about 1sq. metre bigger. I've been left
with numerous large holes all over the place from removing all the ducts
from the warm air heating. Ended up ripping the kitchen out because it
was just not quite bearable and I'm going to fit a new one next week after
it's plastered. Had virgina creeper all over the front and back of the house
most of which has now been removed and left horrible marks behind.
Started the rewiring this week which should be done in a week or two (lots
of data, alarm, audio, TV cables etc...). I was told by the insurance
company that they could not apply discount for it having an intruder alarm
if I installed it myself
! I know that I can install my
alarm better than any staple-gun toting, skirting board-clipping, sling-it-in
alarm fitter. The second fixing has been arranged and will be done by a
NACOSS company and will be connected to a voice dialler and monitored
phone line and will have certificates to say so. This is not good enough
though apparently
, it must be installed by them too. Hoping to
move in sometime early in the new year once I've got heat and electricity
and sort the rest out once I'm in; storage is really expensive and I hate
not being able to lay hands on the things I need because they're boxed up
in a locked storage unit. Have a good Christmas.
spark
though apparently
spark
