Hi
Wonder if someone can help me. I have an immersion heater which was new in 2005. It is for all our hot water and works via a timer I fitted in 2005. Everything was great until 3 day's ago wife said water was hot as hot as it was and it took ages for the hot water to come through. I checked the timer and it's fine. checked across the I/H and have 240 volts (L&N). I by passed the timer just in case and I can hear the I/H hissing away so something is happening. I check the stat and with a neon have live both sides of it however I thought that when I turned it down or up I should hear a click and it turn off (if water already hot) or no if the I/H required heat. What ever i did the neon stayed live both sides. My first though was the stat had broken but then as it's live all the time would not the problem be that the water is too hot??
The next day we still had just warm water even though I left it on all day.
PLease can someone advise me on what to do. Having just been made redundant I don't want to spend loads of money when A) I don't know what the problem is and B) I can't afford it.
Cheers
Bruce
Cheers
Bruce
