Immersion heater thermostat.
30 Aug 2008
Yorkshire
Hi everyone,
We only have electric in our house and so all our hot water is provided by the immersion heater. The water though is far too hot and so I thought I would have a look at the thermostat on the heater. It was set at 40 degrees but I think the water is more like 90. I moved the temp dial to other settings but there is no clicking at all from the thermostat. I think it is safe to say I need a new one. So, I have removed the old thermostat to see what size I need and here is my question. When I removed the thermostat it was bone dry, should it not be wet (hopefully this is not too silly a question)?
Many thanks.
no it should be dry it gos in a sleeve.
if it went straight into the cylinder the cylinder wouldn't hold water.
the thermostat will sit in a sleeve inside the immersion heater. Theyre pretty readilly available, can probably get them from b&q and the likes. Think they go by length so measure yours and get a new one
not in diy sheds you won't get stats on their own.
if its a top mounted immersion it will be 27" long and the stat will be 18" long
