immersion heater
JPC
10 Aug 2004
Leicester
hows do i know if the element has gone or the thermostat.
if the thermostat is knackered then is the immersion heater on all the time or off all the time ?
thx
Disconnect from the mains and measure the resistance through the thermostat and the element seperately, use a multimeter. Only do this if you know what you are doing.
If the thermostst is gone it can be perm or perm off, some stats now have internal resetable overheat button , you can check using multimeter the resistance of the element should be R (ohms)= V 230volts / I 13Amps = 17.60 ohms with cable wires disconnected across live and neural.
Generally if you turn on the immersion and it blows the fuse its the element, this can be tested using an insulation resistance meter (400v) measured live to earth (cylinder) with the wires diconnected. If the goes it overheats or does not heat up at all. Check for votage to stat live to neutral. (check polarity, live is on stat)
:!: Always remove fuse when testing, easy to knock on isolation switch,
