The electrician said the most likely cause of this is to be limescale covering the lower thermostat so it is only heating up the adjacent water and reaching the set temperature quickly.
It could be removed, but as this will involve removing the immersion heater from the cylinder, you might as well just fit a new one.
Unlikely that it would be totally scaled up after just 4 years.
We tried a new thermostat and the problem still persisted and it is already a new immersion but it still keeps cutting out.
How do you disconnect the thermostat and still run the element?
If the immersion was covered in limescale would the water around it heat up in 1-2 minutes even if the thermostat temperature was set at 55/60 degrees?
