I am new to this forum but hope you guys can help...
...I run a business with quite a few hot water cylinders. When the nature of the use changes (ie when we go from a busy period to a quieter period) I find that sometimes the safety cuts in on the immersion thermostats. No problem with it cutting in - it's there to do a job but usually the first I know about it is when the water is cold.
The question is, does anyone know of a thermostat with a light/led which is linked to the cut out so you can see at a glance whether the thermostat safety has cut out?
At the moment I try to listen until I hear the noise of the water heating or feel the pipe to make sure it's warm but it would be so much easier if there was a visual (or audible) way of knowing when the thermostat needed resetting.
Thanks.
Thanks.
