The loft insulation in our house is approx 150mm laid in between the 100mm ceiling joists. which are just a bit further apart than the width of the rolls that were used. So there's a small gap along each row.
I want to increase the insulation, and to store stuff in the roof. So I'm concerned about compressing the insulation and making it less useful.
What's the best way to do this? I know that if you compress 200mm into 100mm then it's only as effective as 100mm.
So, are there other products I can use on top of the existing ceiling joists that will take light loads, like me walking on it?
Are any of the foil products any good?
What's the current building regulation minimum? (as a benchmark)
The roof has eaves vents all round, so I don't want to insulate the rafters.
