Indesit DIF 04 B1 struggling to start
16 Jun 2020
Morning, I have tried to find the answer using the error codes but I cant find a code for the lights I have lit.
Our dishwasher wont complete a cycle, without assistance. If I put it on any of the 4 cycles it starts, does an initial drain, then beeps and doesnt go any further. When I open the door the machine is still trying to drain, even though it is empty. The power light is flashing and then from left to right, lights 1 and 3 are lit but not flashing.
The filter has been cleaned, I've used dishwasher cleaner and a white vinegar mix through it to no avail.
If I added boiling water to it it will run but only if I add it after its finished its initial drain, which makes me think its an intake problem rather than a drainage one.
Help!
Hello
I have exactly the same problem. Have you solved the problem?
