Can anybody interpret the error code of my dishwasher IDL 42 - from left the first and second light are blinking - the washing cycle doesnt even start or it stops after a few minutes.
1 and 2 indicate a communications error. In other words, a problem with the electronics.
Find the pcb (s) , unplug the plugs and plug them back on. If problem still persits you'll need an engineer to repair.
arghhh - i removed all dishes inside cleaner, cleaned the inside filter and the next day it did a full cleaning circle (without dishes). I put the dishes in again and it stopped after 20minutes - same error code. I think i will demount the machine and have try to find the drainage and the pump. Anyway - very strange ....
Thank
