Indesit IWF washing machine, single click but no start with any selected cycle.
That is fascinating never seen any like that before but things move on don't they. The only other thing I can suggest before you buy another sensor is to try the machine in diagnostic mode to see if it points you to any thing else. https://www.google.com/search?q=ind...gUQIRigAZgDAJIHBDQxLjKgB-7lAQ&sclient=gws-wiz Not sure which method will apply to your model but hope it helps
Those video's are fantastic, thanks. Washer looks identical to mine - unfortunately I simply can't get the machine to enter service mode! Tried umpteen times, same result occurs regardless, a click is heard, the door locked indicator is illuminated red, nothing happens.
The model in the title is incorrect, should read IWC (71252).
Also mentioned earlier I'd examined the control board for burn marks, for clarity this was the board sited behind the control switches. There looks to be a box that probably contains a pcb, at right side bottom rear. Lots of wires run in/out of the box. I'll attempt to examine that area, access is awkard.
One odd symptom I've noticed is that when the machine is plugged into the mains power, following 10+ mins unplugged, it immediately lights up the control panel, prompting for start button to be pressed. I would have expected to have to switch the machine on via the on/off button before the 'start cycle' prompt begins?
It seems like you have almost gone through the reset procedure when you have powered on/off. Try it again https://mixrepairs.co.uk/how-to-reset-indesit-washing-machine/ and then try entering diagnotic mode. If you continue to have problems the only other suggestion I can make is that it is time to call a Hotpoint /Indesit engineer out. It would be good to hear the outcome if you do. My GUESS would be that it is a pcb failure but they are a bit expensive to use as a diagnostic part and some have to be programmed on site to the particular model
Can you confirm the model number. If it is IWC 71252 they have a Sole motor and when the motor brushes have worn the door locks and nowt else happens.
They are held on with a 5.5mm socket size screw. Lean the machine securely back to the wall to remove and check them.
Quick update...
Replacement pressure sensor received and installed. Made no difference, original symptoms remain.
The model is indeed IWC 71252. Removed one of the brushes for inspection and there was plenty of meat on it - and it is two 5.5mm hex head screws as mentioned!
Run out of enthusiasm for repairing this unit, can't diagnose root cause and don't want to throw parts at it in hope. A new machine looks likely, an entry level washer can be had for 230 delivered.
Quick update...
My Miele once stopped working after about 18 months. I was advised to check the brushes, One was absolutely fine, the other had worn away. At the time, I simply replaced the one brush, my local supplier only had the one brush...
Replacement brushes arrived yesterday. Removed both existing brushes, one had worn down to approx 4mm, while the other brush still had more than 20mm remaining. Installed new brushes, buttoned up the machine (such was my confidence in getting a result), loaded with clothes and detergent, switched on and set cycle...original fault symptoms remain!!!
Sorry to hear.
Might be a good idea to post to
If they are able to help you, please post back here. This site ranks higher so you will be able to help more people.
As brushes wear down, the carbon from the brushes, is sprayed all around the area of the commutator. That carbon obviously is conductive, and can short out the motor. Some machines test for such issues, before they will begin to operate. So as an additional check, make sure the area around the commutator is clean of carbon.
Cleaned the area thoroughly with electrical contact cleaner spray, sadly didn't make any difference.
Frustrating that I can't locate the root cause of the fault, no doubt something simple. Don't want to keep throwing new parts at it in desperation, when a replacement is relatively low cost.
New machine was delivered Thursday.
Many thanks to all for taking the time to provide advice.
