Indesit W123 not spinning
2 Jun 2005
Oxford
Please help,
I have an Indesit W123. it does not spin during the wash cycle nor in the final spin. I have tried replacing the brushes to no avail. The motor sounds like it is trying to spin but it seems as if there is not enough power.
I gave the drum a helping hand and this seems to get it going for a while but when I stopped helping it is not capable of rotating the drum by itself.
Thanks in advance.
Jamie.
I happened upon your message whilst searching for something else, but if it helps, I had a similar symptom on a tumble dryer some time ago. The drum wouldn't turn, but could be made to start with a push. Otherwise the motor just buzzed.
Fault turned out to be a faulty phasing capacitor in the motor supply - usually a large electrolytic mounted on the chassis somewhere. An induction motor needs this to establish a phase shift in the windings to get it rotating.
I don't know the particular machine well (although my indesit is currently making expensive noises and chewing sheets - lid off tomorrow!) but I hope my suggestion is helpful.
I got a suitable cap for the tumble dryer from RS for about a fiver.
Hi Brucci,
Thanks for your reply. Pardon me for being a bit of a novice but. Where would I find the phasing capacitor in the motor supply - usually a large electrolytic mounted on the chassis somewhere? Would it have wires going to the motor?
Also where is? Do you have a link or something. I got a suitable cap for the tumble dryer from RS for about a fiver.
Thanks again. If anyone has further suggestions I gladly like to hear them.
Thanks.
images
usually attatched to the motor
induction motors do not have brushes (thats why they are induction motors) since the brushes have been changed (as mentioned by origonal poster) it pointless looking for a capacitor that isnt there.
all te w/s i saw never had a capacitor for the motor, t/d yes, wm no
i would suggest either the motor or motor control board
Jamie, yes, I think you need a new motor. Breezer, for information, some washing machines, particularly older, low spin speed models from Servis, Bendix, Zanussi, Philco etc did use induction motors but they are not very common these days. Some had 2 capacitors, one for wash and one for spin.
fair comment fido, but Jamie.Downs did say
so as i said
so it cant be an induction motor
but i didnt know some very old m/c had two capacitors, all the hp ones i have seen (some were older than old) never had induction motors (except the twin tub whch was an induction motor :)
Thank you very much for all your suggestions. Do you have any suggestions of where I could get a motor from?
Thanks again.
Sorry Breezer, I was not suggesting that this machine has an induction motor, just pointing out that there are such machines in use. :)
