Hi. We have an Indesit front load washer dryer and recently started hearing occasional banging/clattering during the spin cycles. The last time we used it it got so bad that the machine started jumping around and sounded like it was about to explode! I did some reading and checked out the machine as good as I could, and realised that there was something trapped *behind* the drum at about 3 o'clock as you look head on inside the drum. (there's no play in the bearings, and the concrete blocks/springs/dampers are all fine) This is *inside* the outer drum casing, but behind the metal inner drum.
Using a torch and looking through the drum holes I was able to see that the object that is grinding against the back of the drum (when turned by hand) seems to be made of metal, a flat sheet (or possibly curved, hard to tell) around 5 inches by 4 inches (ish), and perforated. Lots of holes. A machined piece.
It's obviously nothing we've left in a pocket or anything but is a part of the machine that has become loose/out of place and is catching on the rear indentations of the drum with every turn.
I've been unable to find out what this piece is. Anybody able to help me?
