I have an indirect fired hot water tank that runs off the boiler. At times the demand for hot water might exceed 1 hour at wich time it stops heating the water. The indirect has a priority plus wiring diagram and I see that it is jumped out. I have removed the jumper but the tank still will not provide hot water after 1 hour. Inside the control diagram it does say that if run for more than an hour it will shut down. Can anyone help me so I can get this hot water after the safety 1 hour passes? Thank you much for your reply in advance.
