right i have now got the outside aerial cable working the channels loaded ok but the picture on all channels freezes or crackles every now and then any one any ideas
Could be a few things - Your post doesn't give enough info to make more than a few general suggestions though...
Freezing - Not enough signal.
Could be caused by...
poor aerial alignment
wrong type of aerial (old/wrong spec/insufficient gain)
broken aerial
bad cable connection (at the aerial junction/at the plug end)
damaged cable (broken/corroded/water ingress)
requires signal booster
Care to give a bit more info about the outdoor aerial - A new install, or an old one you've just managed to get working?
i fitted it myself about a year ago for the tv in my bedroom that works ok i have run a cable to the other bedroom through a booster when its connected it has a good picture then will freeze/crackle every now and then if i swap the cables in the booster over to my bedroom cable it works ok perhaps the boosters not man enough
it was a digital aerial i fitted as well the booster is a 2 tv one from wickes but i dont know how old it is all the cables are good connections
