Hi,I have a new aeg induction hob which draws 16amps at 230v.I have to run a feed for it up the wall from a cooker switch across under the floor upstairs and down to the fuse board,total legnth of run 45 feet.
Is 6mm T&E ok for the cable and would a 32amp rcbo be suitable protection or could i use a 20amp rcd.
I am doing a house rebuild myself and everything i do is checked before it is connected by a qualified electrician.
Thanks for any advice.
