I have a Trevi Therm mk 2 shower unit (the exposed one) from around 2006 or so.
Having moved house we removed it and wish to fit it as a stopgap measure to replace an existing mixer which doesnt work before we refit the shower room later in the year.
Does anyone have a copy of the installation instructions? I will almost certainly have to reset the temperature controls as it is moving from a low pressure to a high pressure system.
I also see that there are now two variants - one where the outlet is at the bottom and one where the outlet is at the top. The valve body I have has a hex plug in the top and an internal hex to (presumably) remove to outlet at the bottom. Can I simply swap these over rather than change the pipework!
TIA
Kevin
TIA
Kevin
