Sorry - put this in the wrong forum so I'll try again here....
Hi guys - there's been a few simliar threads but I can't quite find one to match mine. I am replacing a basic ceiling rose with a 3 halogen spot. The halogen fitting has two connections for L and N (brown and blue). It also has a screw for earth attached to the casing. From the ceiling I have 3 cables, two have the usual red/black/green, one has red and white which I assume is the switch cable. The 3 reds are wired together as are the 2 blacks and the 2 greens with the white by itself. The previous fitting had 4 screws.
I want to know how to wire the new fitting with this setup - do I need another choc block for instance ? The main thing I suppose is bringing the switch into play.........
