Installing a bit shorter radiators?
16 May 2011
Hi
I am installing two new radiators in my flat.
The length, point to point measurement, of the old radiators is 645 mm and 840 mm.
The length, point to point measurement, of the new radiators is 628 mm and 812 mm.
The pipes come out vertically from the floor for about 200 mm.
Will the new ones fit or I may damage the pipes trying to install the new slightly sorter radiators?
Can I bent a bit the pipes or use any kind of extension?
I would not advise bending the copper that far! Better to use extension pieces. These are readily available in various sizes from plumbers merchants. Without using extensions it can be done with copper pipe something like this. View media item 39743
