Installing CM927 on valliant ECOMAX
22 May 2013
Yorkshire
Hi.
Firstly, thank you if a response is given to my query.
I have seen a few post regarding installing Honeywell 927 thermostats but wanted to clarify my setup to see if clear advise could be provided.
Currently I have an analogue Honeywell connected into a Vaillant ecomax boiler via bins 3, 4 and 5. I want to replace this with a Honeywell CM927 and wanted to see if it is possible without running new cables.
Could someone please advise how to connect a CM927 to a vaillant boiler and if I need a 4 core or will a 3 core be sufficient.
Thanks again
Just to clarify Dan's question:
927 - remote RF sensor/controls with receiver wired to boiler
907 - sensor/controls direct wired to boiler
I'm all for the universe making me a better idiot.
In this instance though its the CM927 as listed in my original post, I'm not sure what type of ECO Max boiler it is.
Hi, would anybody be able to offer some assistance.
I understand that on the vaillant pin outs 3, 4 and 5 are the area to connect, but I am unsure how to connect the 927 to these connects
So it definitely needs 4 connections I can't use a 3 pair and connect the second L to the A
Will any of the more sophisticated Vaillant controls modulate an Ecomax?
