- Joined
- 3 Oct 2017
- Messages
- 4
- Reaction score
- 0
- Country
Hello,
I'm currently installing these LED tube lights in my garage (https://www.amazon.co.uk/Fluorescent-Replacement-daylight-ultra-light-unbreakable/dp/B00XN3CGJO) using these fixtures (https://www.simplelighting.co.uk/2-120-cm-batten-fitting/).
I have the fixtures hooked up to mains plugs running to one socket (I am a total novice when it comes to anything electrical and thought this would be the easiest way).
I have 2 twin-tube 4ft fittings attached to a switched 3 way adapter, attached to an extension cable which is attached to a multi-socket extension lead. 1 further twin-tube 4ft fitting is attached directly to the multi socket extension lead. All 3 fittings are running to the same socket.
Unfortunately a few of the lights flicker and the socket is making a crackling sound whenever I try to run them all at once.
The instruction manuals that come with the fittings and tubes don't seem to have much info, but I've tried to narrow it down to a few possible problems.
1 - The tubes I have are retrofit and require a magnetic ballast to work correctly? (The fixtures have no ballast and are direct wire LED only?)
2- My adapter/extension lead/multi socket combo is too complex/dangerous?
3- The overall amp load from 3 fixtures and an electric garage door opener is too high for one socket?
4- There is a problem with the socket (the wiring in the garage generally looks old)?
5- Something else?
Any help would be greatly appreciated, just want to see if there's some simple I'm missing before I get an electrician in the have a look.
Cheers,
Brian
5- Something else?
Cheers,
Brian
