I want to install a loft light. I was up at the weekend scoping the job out.
I currently have a junction box in the loft that the previous occupant had installed. This appears to tap into the existing circuit (landing light). This JB then has a feed to a switched FCU which controls the outside floodlight (on a sensor).
This is what I propose to do:-
Tap into this JB and take a new feed (1mm T&E) to a new pendant rose. Then from the pendant rose to the new switch. ‘I’m thinking of doing it this way as then I have a switched live to my new light rather than taking a feed to the switch and connecting the neutrals together at the switch then to the pendant.
Would this be a correct method of doing this?
Could I use a pull cord switch?
