Installing Under Sink Water Heater - Unvented?
26 Nov 2004
I've managed to lay my hands on a Zip aquapoint II water heater that I want to install in my garage under the sink, the installation notes I have come across mention various valves.....The installation that it was in previously had nothing apart from a service valve. I'm tempted to bang it in in the same way but my sensible side says I shouldn't! Are you meant to be registered to carry out this type of installation?
I'm going to do it myself regardless :oops: So some tips would be handy.....
Mine is the 10l one
PDF LINK TO INSTRUCTIONS
Thanks in advance as always guys :D [/url]
Instructions are self explanatory, especially the bit which says:
"Electrical
• To be wired to a double pole fused spur, minimum break rating
of 13 amps
• Installation must comply with current IEE regulations"
which is notifyable to BCO, or use an electrician.
So, that's the legalities aside, what do you want to know :wink:
You don't have to be G3 registered as the capacity is under 15 litres. Follow the instructions though and put a relief valve in, and an expansion vessel if you don't have sufficient pipework to accomodate the expansion. If you don't have a relief valve and the stat fails the water in the unit could boil, at which point you will have a quite spectacular explosion.
9' of pipe between nearest cold water draw off and the heater? Is this right and why? <---will make it a nightmare to fit as the nearest cold water draw off is about 3' away.
Is that instead of a expansion vessel? I could make a maze of copper under the sink :twisted:
If water pressure is above 4 bar, what is the easiest way of installing? It must be the couple of thatchers I've had....I'm not understanding.
If I need the following....
Where can I buy a suitable expansion relief valve & expansion vessel?
Thanks again.
