insulate central heating pipes
29 Oct 2009
guys,
22mm central heating runs ran under ground floor in the cavity. Double clipped next to each other so the standard 19mm insulation does not fit now. Cant even get the 13mm round either. So far on pipes that run under the joists, I have fitted one length, then trimmed down another and sort of wedged and taped together. However where the runs are parallel with joists I have put some of that spiral wrap stuff and tbh I ain't that keen on it.
What do you guys do?
Is there anything I can do?
cheers
