Good Morning
I'm in the process of converting my basement into a bedroom with ensuite shower room
The walls/floor have been tanked with a sika 1 mix because the building is located next to a canal and 2 of the walls are below ground level
The problem i have is that i have to provide insulation and a finish to the walls whilst keeping the additional thickness to a minimum
Is anyone aware of a product that contains around 50mm insulation and plasterboard? if so is it possible to fix this to the wall without penetrating the waterproof barrier?
Tim
Tim
