I'm just ordering for building an insulated slab foundation for a garage/workshop. My plan is to lay XPS insulation in the slab and have it join to form continuous insulation with external wall insulation.
I'm just wondering whether it would be best to build an insulated form for pouring the concrete, and then add EWI down to that - or just insulate underneath the slab, pour into a concrete form, and then use EWI to insulate down to that. Also, curious if anyone has any opinions on where the DPM should go. I'm planning on adding a Vapour permeable membrane (red) between the concrete and XPS (help prevent leaks during the pour too). Should I also add a DPM course under the first layer of blocks?
Here's the two options I'm considering:
