I have a back room which is very cold, I think because 1/3 of it has its own roof space - it's one of those boxes that pokes out the back of the house. Problem is the pitched tiled roof space above it is totally inaccessible - in the loft the brick wall is all that is visible. What would be the best way to insulate the space? Seems possible to drill a hole from inside the loft into the space, or perhaps through the ceiling from inside the room, then inject foam or particles. It's not a very massive space, ceiling area only about 9x6ft. Is this a professional job or can I do a budget bodge by squirting some cans of expanding foam filler in there? I guess it would be easy enough to calculate the number of cans needed, but would it fill it or would just end up with a big blob around the filling hole and the rest of the space empty? I wouldn't want to have to get into removing a whole brick in order to check with a torch! House is about 90 years old by the way. If I can't fill the space the only alternative I can think of is putting in a false ceiling with insulation above it - but that's a bit naff and would spoil the look of the room, although the ceiling is high enough for it.
