Insulating a plastered solid wall
25 Apr 2010
Hi all,
Quite a few posts on this area already I know but can't find anything about this specific question.
We've moved into a 1920's solid walled place that gets cold in the winter (surprise surprise) even with new central heating up to full. The radiators are old mind, and we're having those changed for newer efficient ones asap. Also had draughty old front and back doors, both of which've just been changed too.
The walls are pretty aesthetically crap and whilst the plasterwork's solid it needs reskimming. We though that at the same time we'd insulate the internal walls, especially as we were also changing the rads that are mounted on them too. But our plasterer recommended that there were a number of ways to do it; dot and dab regular plasterboard and let the air gap act as an insulator or put up thermalboard.
He seemed to think that given the changes that we've already made (doors) and are going to make (more efficient rads) that regular plasterboard dotted and dabbed would be sufficient. But having read a bit about this I'm not so sure. We did talk about thermalboard and whilst it'd add only about 6% to the overall bill it will mean it'd bring the wall beyond the level of the windowsills. But couldn't we just add wood to the sills, filler and re-paint?
Any thoughts on the best way forward much appreciated!
Hi all,
get the cavity insulated my house has it, and i dont need any central heating what so ever my house is as warm as toast in the winter
His house doesn't have cavity walls so yes using thermal board would make a big difference - about 30 - 35% I'd imagine. Your freezer only has an inch of polystyrene insulation and that keeps the inside very cold.
