I've just moved into a 1930's detached house where the ground floor is wooden (old planks) and about 18 inches above ground. Basically the whole downstairs is freezing and doesn't really warmup so I am looking to rip out old the floorboards and put in new ones and then carpet. I have done some research into how i can best insulate (given that all the work has to be done from above) and the best suggestion seems to be to lay loft insulation supported on rot-proof mesh between the joists. I can see that attaching mesh to bottom of joists will be a tricky operation so was wondering if there was anything else i can do as i will have the whole floor up anyway?
Thanks,
Thanks,
