Semi Basement constructed from 325mm concrete blocks and infilled with C35 concrete and rebar.
Walls have been tanked using KA Tanking Slurry. The floor has 100mm rigid insulation and a concrete slab. Wet UFH heating will be installed.
Next step is to add in some insulation. Which would be a good choice here:
1.Dot n Dab insulated plaster boards directly onto the tanked walls. (any one had any experience of D&D over tanking slurry?)
2.Create a stud frame and install rigid board insulation, cover with vapor a barrier and then plaster board on top. (the timber frame will breach the tanking in the areas it will need to be fixed to the walls).
3. any other suggested method(s)?
Being a basement general concern is to keep condensation to a minimum.
Many thanks.
Steve
Many thanks.
Steve
