- Joined
- 18 Jul 2025
- Messages
- 2
- Reaction score
- 0
- Country
Looking for some advice on the best way to insulate the ceiling of my garage.
It’s an attached garage and a heated room above built in the 80s. The garage ceiling isn’t currently insulated, and during winter, the floor above gets quite cold, even though it’s carpeted.
I'm planning to insulate the garage ceiling from below to improve the comfort of the room upstairs, but want to make sure it is being done correctly. My thinking is:
Use Knauf Loft Roll or Rockwool between the ceiling joists and just board it with moisture resistance board, not going to bother with skimming it either.
A few questions I have:
Is this the right approach, or is there a better alternative?
Do I need an air gap to avoid condensation and if so, where should it go?
Do I need a vapour barrier?
The garage isn't heated and has small draughts under the garage door. The ceiling is boarded up with some sort of beige/yellowish plasterboard at the moment which I haven't seen before. No sign of mould or condensation so far.
My aim is simply want the floor of the heated warmer during the winter without overcomplicating things and doing more harm than good. Appreciate any pointers.
