I want to insulate my loft , I have increased the height of the joists from 80mm to 140mm and thrown away all of old mineral wall as it was damp and not in great condition. I have fixed all damp issues now.
So also want to board over joists for light storage using 22mm chip board. I therefore have 140mm depth for insulation. I know if you use mineral wool only the level required is 270mm. Obviously I cannot do this but want to retain the same insulation value that 270mm of mineral wool would give me.
My suggestion is to to use 100mm of mineral wool as a base and then 50mm insulation board (celotex) on top of this pushing down the mineral by 10ml. I know you shouldn't squish mineral wool too much but I hoped if it was only 10ml this would be ok.
So would 100mm mineral wool with 50mm celotex board on too be as efficient as 270mm mineral wool?
