I have a modern designer gas fire with a steel flue pipe then comes out of the back and through the wall to the outside. The fire sits on a plynth about 30cm from the wall. The hole in the wall on the inside is larger than the pipe and I am getting a draught through the cavity.
What can I use to block the gap that can take the heat from the flue pipe?
