Insulating solid wall and bay window
23 Nov 2026
Hi all,
I am planning to insulate the solid wall and bay window in the children’s new room, as it is very cold. My plan is to fit insulated plasterboard to the solid wall and bay, using the following product:
IKO Enertherm Insulated PIR Plasterboard, 52.5mm. For the window reveals, I plan to use tile backer board. There are currently no signs of damp, so I intend to fix the boards over the existing plaster using plasterboard adhesive using the dot and dab method.
Is there any benefit to removing the existing plaster and going back to bare brick, other than gaining some space? Would you also insulate the boxed-in section on the ceiling to match the depth of the insulation on the sides?
Any tips or advice on good practice would be much appreciated, as I plan to repeat the same work in our downstairs living room. I also plan to insulate the floor to help keep the room warmer. I have previously installed a bigger radiator, and the difference has been minimal.
Is there any suggestions on alterative productions or using low expanding foam adhesive?
Many thanks
Aky
