- Joined
- 7 Feb 2018
- Messages
- 147
- Reaction score
- 12
- Country
Good luck with that
Assuming you can read
Surely, if the air bricks are all clear then vapour barrier is not essential? Yes, it would be better, but if the subfloor is ventilated then the moist air is not going to hang around for long...
my house, all air bricks were sealed / covered. No insulation, but the electrics were done with junction boxes on the floor. Apparently the previous owner was forever having powercuts, probably due to junction boxes getting wet from condensation.
This is why PIR is foil faced and you are required to seal the joints with foil tape.
Find some evidence of that “BCO requirement” please.
There is none and I've inspected hundreds, we had some pretty severe flooding when a river burst it banks a few years ago affecting several hundred properties mainly in my part of the city, most of which required new floors. Didn't see or request a single vapour barrier.Find some evidence of that “BCO requirement” please.
Apologies, I thought this was a fairly simple concept.
I've not seen a vapour barrier installed once in this situation since the introduction of insulation in floors in the B Regs, I've yet to hear of a problem, though with a vented sub floor I can't see why you would.Tell us about some of the occasions you've personally found interstitial condensation in a ventilated wooden ground floor.
Lofts are different because ceilings are not vapour permeable..
It does that's why you ventilate over the insulation or use a warm roof.I thought vapour could pass through normal plasterboard and paint - if ceilings are not vapour impermeable, how are walls different? #confused
