We have an old room in the loft (1920s semi) which, for now, is used for a home office. There is no insulation whatsoever between the loft floor and ceiling below which is a gap of about 140mm. For the time being, I can't increase the depth here so need to take an interim step so at least there's some kind of insulation. As of now, I'm planning to put 100mm Rockwool RW3 slabs in which I think should help matters without leading to moisture build-up.
My question is whether I need to leave any space between the insulation and the loft boards or if I can go ahead and add a 30mm layer to more or less fill it top to bottom.
Thanks in advance,
Matt
Thanks in advance,
Matt
