Insulation between new build walls
17 May 2016
Hi, I have a Persimmon home and it's freezing and doesn't retain heat. I wondered if anyone might know whether there is meant to be insulation in the cavity between walls. From some pictures I took of the original construction it seems that is missing, if it's meant to be in there. Any thoughts appreciated! Thanks
That depends on the construction method. 'Partial fill' construction means that whilst you will still see a clear cavity, there is insulation present. This is fitted close against the internal blockwork (cavity side).
Other builders fill an empty cavity after the building is finished using blown in gear.
As long as their is no air movement, an empty cavity is not the end of the world.
We are now building with full fill PIR (90mm rebated PIR in a 100mm cav') which gives 0.18 W/m²K, and is the minimum which we adhere to, in order to satisfy reg's.
