hi, apologies for covering well trodden ground, but I can't find a direct answer in previous posts.
I've recently moved into a new build house that has a single ply flat roof supported by king post trusses. There's not much storage space, so we wanted to board part of the loft. I've got some loft boards to screw over the joists, but I'm a bit stuck as to what to do with the insulation.
Unfortunately the joist and rafter spaces are only 70mm deep.
At present there's 270mm of glass-wool laid over and for the time being I've placed some of the glasswool insulation between the joists. Obviously this isn't going to be sufficient thickness and it's going to be compressed once boarded. I'd looked into using space board on top but it's required thickness would reduce the height to an unusable level (I'm already struggling to crawl around as it is and the trusses limit accessibility).
I was thinking of laying down PIR board like Celotex 70mm between joists and then counter-battening to place another 30mm across to reach the required 100mm. however I wasn't sure if you can then lay chipboard straight on top or you need 50mm ventilation space, which would again reduce the useable space to the point of negating any worth to the project.
If not possible, is it an option to split the 100mm between rafters and joists by adding 30mm battens to each and 50mm board insulation. If done where would I have to put the vapour control layer?
The other option I wondered about was using a multi-layer foil product like thinsulex to top up the insulation, but I'm not sure whether I'd need to put it in a layer over 25mm batten across the joists to provide the required air gap and then put the chipboard on top or whether it's better to staple it to the rafters. most of what I've read says that foil by itself rarely lives up to it's billed R rating, with only hybrid systems being certified and that it needs an air gap to perform well. However I've not found anything that actually describes how to properly combine them. I'd have thought that given the glasswool insulation is by definition filled with air it should be ok to layer the foil over it directly.
Also one thing that confuses me is that because the trusses are present throughout, whatever solution I go for, surely there'll always be a thermal bridge present and there's no way to get a completely tight vapour barrier.
any help/suggestions much appreciated!
Julian
Julian
