Insulation over cables
7 Jan 2009
Warwickshire
Good evening. Im not sure this topic was fully answered. In my loft it has very little loft insulation.
The cabling has been run under joists, pulled tight etc. Therefore it is impossible to lift it above any insulation.
I dont want to insulate directly over the wires as it sounds like this will probably will be ok but is not advisable.
Therefore what should I do.
1. Put down battens, board over the cables and then put the insulation over the top of this, therefore giving the wiring some breathing space?
2. Somehow extend the wiring by connecting new cable to the existing wires via connectors thus giving it a bit slack etc.
Any other options? All seem like a bit of graft but have no probs with that.
They are just touching the plasterboard (looks like they weren't overly interested in Insulation in the 70's) and they are just lighting. However the wiring is fairly old.
