Integral garage conversion & ventilation
6 Nov 2008
I have an integral garage which we have now partioned off three quarters of it to build a home office.
This leaves a small garage at the front with up & over door and the new room we have created is accesed from the outside by a single double glazed door only. (No other access)
i have read that ventilation may be required?
Can anyone advise on this.
It should be vented to the open air. You might have a petrol lawnmower with a leaking fuel tank in the garage and which won't exactly provide fresh air to the office.
Put a cat flap in the door?
The requirement is for ventilation not extraction.
Why can't you just put a vent in the door, the frame or the wall and not make something which is easy, complicated?
A vent in the door look ****e
Im just not gonna bother. Im not sleeping in there. Simples.
A trickle vent is about 15mm thick! Same colour as the door or frame, and you are saying it will be so noticeable as to affect the whole aesthetic?
Oh a trickle vent. Not a stonking great big vent in the door?
Are you sure ventilation is the only requirement if you have created a heated office :?::!:
OMG its the monster vent thread.
Listen, you need 5,000 mm² equivalent area of trickle ventilation, and rapid ventilation equivalent to 1/20th of the floor area - ie open the door.
