- Joined
- 13 Dec 2023
- Messages
- 36
- Reaction score
- 4
- Country
Ok so I've looked in the current threads for an answer but so far had no luck in describing my situation.
I have an integrated Bosch Exccel (I think!) dishwasher that has suddenly stopped working. It has just a simple manual dial/timer to select the three washing modes, and an on/off button, but no error code or lights.
When I select a programme, the machine will make the usual sounds at first; gurgling, as if draining the bottom of the cabin, but then doesn't progress any further. I can hear the usual whirring, the manual timer progresses, and a click every 20 seconds or so (not sure if clicks were there before) - but that is it. The timer progresses but the programme doesn't. If I open the door quickly, I can see water dribble out of the lower spray arm, but that's it. I've removed the bottom filter cover, filter and the impeller cover with a torx screw driver - they and the impeller all look fine- no sign of any lockage or debris.
So what is next to check ? And do the symptoms described suggest what might be broken ?
TIA
TIA
