integrated fridge door binds on hinge
21 Jul 2010
Weymouth, Dorset
I am changing my old built in F/F for one of the large capacity AEG models. But my current unit has a problem where the hinge binds on the fridge door.
I can see that there is very little room for manoeuvre with the placement of the fridge, but I does look like the hinges could be slimmer.
To prevent this happening again on the new fridge, what steps should I take?
very difficult to get a camera in there to show what's happening. But basically, the edge of the fridge door binds on the hinges of the cabinet door.
I'm looking at the pics, but I can't work out how it solves the problem.
This is a hinge on the enclosure, for a cosmetic door that opens at the same time as the appliance door, and is atached with a sliding strap or something, is that right?
what is different between the new hinge and the old hinge?
I'm sure it's obvious when you know :?
not sure if I'm correct here, but my current hinges are 20mm high at the point where they bind on the f/f door edge. Lowering that height by 4mm should give that extra wiggle room when it comes to fitting.
Blum seem to tout these hinges specifically for built in f/f and they say they are only 16mm high.
from the Blum catalogue for Modulus hinges:
Hinge for refrigerator or appliance doors - Shallow hinge arm height
- All metal hinge, nickel plated
- 94° opening angle
- With closing mechanism (spring)
- Slide on hinge arm
- 3-dimensional adjustment (with relevant
mounting plate)
then there is a drawing that indicates the arm height is 16mm, measuring my hinge at the same place is 20mm. So i am assuming that the extra 4mm will allow the fridge door to clear the hinge more easily.
